BTRFS compression disabled after reboot
obvious
Spain
Post by obvious »
Hello TerraMaster:
With TOS 6.0.577 and TOS 6.0.610 and tested in several boxes (F8 Plus & F4 424 Max):
When BTRFS compression is enabled it works until the system is restarted. Once the system is rebooted the BTRFS filesystem is no longer mounted with compression enabled.
Before reboot:
/dev/mapper/vg0-lv0 on /Volume1 type btrfs (rw,noatime,compress=zlib:4,ssd,space_cache=v2,subvolid=256,subvol=/@)
After reboot:
/dev/mapper/vg0-lv0 on /Volume1 type btrfs (rw,noatime,ssd,space_cache=v2,subvolid=256,subvol=/@)
If compression settings are modified, then compression is reenabled... until next reboot...
On the Control Panel side, the compression setting looks "enabled" but the filesystem its not mounted with compression enabled.
Thank you.
Regards!
TMbuddy
Re: BTRFS compression disabled after reboot
Post by TMbuddy »
obvious wrote: 17 Jan 2025, 04:45
Hello, thank you very much for your valuable feedback. The issue with the file system compression is a known bug that is yet to be fixed. Please stay tuned for updates in our future versions, and we will resolve this issue as soon as possible.
obvious
Spain
Post by obvious »
Thank you very much.
Meanwhile I have disabled btrfs compression.
I hope to hear from you soon
