F4-424 how to reach max MHz (3,7) on N95
yoshihisa9
Post by yoshihisa9 »
Hello!
how can i change max tdp in bios of f4-424?
Now i see lock on 15w and cpu work only in 1700 MHz, how can ia change this?
Valnjes
Austria
Re: F4-424 max tdp and max MHz
Post by Valnjes »
What version of the F4-424?
F4-424 (N95)
F4-424 Pro (N305)
F4-424 Max (1235U)
Dont replace the thermal-pad with thermal paste, because your temperature will get worse.
If you have to replace the pad, then with the PTM7950.
What helped me (N305) is to put the PTM7950 and a good fan -> be quiet! Pure Wings 3 PWM 120mm.
With DSM i can run it at 3GHz all time.
yoshihisa9
Hi!
I have F4-424 (N95), cpu can reach only 1700 mhz, so i dont have problem whith temperature (max 70 c). I need to set max clock 3400 in turbo mode.
I have installed DSM 7.2.1 and model DS920+
Valnjes
Austria
Re: F4-424 how to reach max MHz (3,7) on N95
Post by Valnjes »
When you are in the setup of your ARC Bootloader, select custom choose performance mode.
