Upgrading from 5.1.131-00123 when none of the links work
dhathaway
Post by dhathaway »
I saw in a recent email that TOS 6 was available. I followed the link to find that the requirement to TOS 6 is to run 5.1.145 or higher.
The instructions to upgrade 5.1.145 or higher there say that I should run the update in the Control Panel > System > Update. However there it says "Current system is the latest version".
OK, so I attempt to download via a browser, but I get nothing at all. Changing to command line, I get "HTTP ERROR response 403 Forbidden"
❯ wget 'https://download3.terra-master.com/TOS%20packages/TOS%20update%20packages/5.1/x.64/TOS_X642.0_Update_5.1.145_00012_2407
270535.bz2'
HTTP ERROR response 403 Forbidden [https://download3.terra-master.com/TOS%20packages/TOS%20update%20packages/5.1/x.64/TOS_X642.TOS_X642.0_Update_5.
I try the same thing with 6.0.530 and get the same response.
Please inform me what the proper method is to get my system up to date.
Or, perhaps this is a case of "if it ain't broke, don't fix it". My system is too valuable to risk it.
Re: Upgrading from 5.1.131-00123 when none of the links work
When you use the command download on TOS 5, you need to use the "ter_wget" command.
You can try copying the link to a different browser to download it or check if the browser is blocking it.
You can refer to the following link to update:
viewtopic.php?t=6355
viewtopic.php?t=6809
FYI Browser downloads were working ok yesterday. I checked after reading the original post.
Return to “System Update”
