I tried to downgrade my Tos version but now my Nas want to be instal the new TOS version wich doesn't anymore exists on TerraMaster website.
So i need help
Need original TOS for F4-210
Re: Need original TOS for F4-210
Why you need to downgrade the os?
here is the latest version of tos, please update it to the latest version.
viewtopic.php?f=28&t=711
have a look what it shows me after all that...
and when i trie to download aotomaticly, it goes up to 50% but not more.
I was on tha terramaster website an under "downloas" there is no more TOS version
You can download the installation package from this link first http://dl.terra-master.com/cn/TOS_A1.0_ ... 291655.ins and select "Manually download and install TOS".
after 15 Minutes still the same:
Just take a little longer to study your case, I afraid something wrong during you update your TOS. please try following:
1. pull all your drives out;
2. insert another healthy drive;
3. install again the TOS, I recommand the latest one;
4. after installation complete, pull out your drive;
5. insert your previous drives, and install the os again.
if there is still issue there, please let me know.
same error, I let it run over night but this morning, nothing changed...
The system was failed to install on your hard drive, you need to replace your drives.
TMsupport3
Please format the HDD in low level format on PC first even it is empty, then use it in TerraMaster NAS.
