TerraSync in windows cannot delete folders error 0x80070185 cloud operation is unsuccessful
TerraSync is a cloud drive service application that helps users build their own private cloud drive services with their TNAS devices.
rvescovi
Italy
Post by rvescovi »
After installed TerraSync windows client and synchronized bidirectional, I'm able to create files and directories from windows file manager but when I try to delete any folders I receive a popup error: 0x80070185 cloud operation is unsuccessful.
Even renaming is not possible of previously successfully created folders.
TOS 6 577
TNAS PC for Windows v. 5.2.021
Thanks.
TMpzhen
Re: TerraSync in windows cannot delete folders error 0x80070185 cloud operation is unsuccessful
Post by TMpzhen »
Are you editing a cloud state folder on Windows?
rvescovi
Italy
Post by rvescovi »
No, I'm simply trying to delete a folder from Windows File Explorer. The folder is under TerraSync syncronization with the NAS.
I can create the folder but nor delete and neither renaming it.
TMeric
Post by TMeric »
The new versions of TerraSync 1.1.845 and TNAS PC 5.2.088 have been released. Please update to the latest versions and check if the issue persists. If you encounter any issues, feel free to contact us. Thank you.
CodeHunter
Algeria
Post by CodeHunter »
TMeric wrote: 06 Feb 2025, 11:52
Same problem here, but luckily the update issue’s all fixed now! Huge thanks for the help!
Return to “TerraSync”
