D5-300 randomly disonnecting disk 5
sco0by
Post by sco0by »
Hi All,
I have a D5-300 with 5x Toshiba 8tb N300 disks in it.
It has developed a fault where it thinks that Disk 5 is unplugged then inserted. The log in RAID manager shows the unplugged/inserted as happening one after the other. This is without powering the unit off or touching it in any way. It is also powered via a UPS so it is not a power issue.
After the unplugged/inserted event is logged the array then goes into reconstruction state.
It happened a couple of times, I tried swapping disk 5 out for a spare 8tb drive but the same thing happened.
Any suggestions, or is this likely to be a hardware fault with the D5-300 itself?
Thanks in advance!
IrisLi
Re: D5-300 randomly disonnecting disk 5
Post by IrisLi »
sco0by wrote: 29 Dec 2024, 05:04
If possible, please insert the hard drive separately into the slot of disk 5 and check if there is such a phenomenon, in order to investigate whether it is a problem of poor hard drive contact.
Will this phenomenon still occur after recreating the array for all disks.
Additionally, your disk is not on the compatibility list, which could be due to compatibility issues.
Compatibility List:
https://www.terra-master.com/global/compatibility/
Return to “USB Series”
