F$-424 pro nvnm disk 2 to hot
andrevanderweide
Netherlands
Post by andrevanderweide »
My f4-424 pro give this Disk tenperature too high, Disk name: NVMe Disk2
but when i lok with infra red he is 24-25C als NVMe drive 1 is also not hot
I have tos 6.0.577 Bios/initBoot MADNo1o1.v05
Re: F$-424 pro nvnm disk 2 to hot
what is your disk model and brand? it is on the compatible list?
andrevanderweide
Netherlands
its a samsung 1tb 980 same is on the list i put yesterday coolingblok on it and last night its ok no overheating message more .
i wil keep looking the next days if it occurs again
andrevanderweide
Netherlands
i had it again
andrevanderweide
Netherlands
few minutes ago i reinstall photos app and i did get the same again
We have recorded individual M.2 SSDs with one too high and one normal temperature for both sensors.
We suggest you to check through this command to see if your SSD has a similar situation:
nvme smart-log /dev/sdzb
andrevanderweide
Netherlands
Smart Log for NVME device:sdzb namespace-id:ffffffff
critical_warning : 0
temperature : 39 C (312 Kelvin)
available_spare : 100%
available_spare_threshold : 10%
percentage_used : 1%
endurance group critical warning summary: 0
data_units_read : 21300142
data_units_written : 17749749
host_read_commands : 379550001
host_write_commands : 324351936
controller_busy_time : 901
power_cycles : 606
power_on_hours : 401
unsafe_shutdowns : 34
media_errors : 0
num_err_log_entries : 0
Warning Temperature Time : 4
Critical Composite Temperature Time : 0
Temperature Sensor 1 : 39 C (312 Kelvin)
Temperature Sensor 2 : 35 C (308 Kelvin)
Thermal Management T1 Trans Count : 0
Thermal Management T2 Trans Count : 954
Thermal Management T1 Total Time : 0
Thermal Management T2 Total Time : 218
Return to “System Resources”
