TOS 6.0.577 (X86) is Released for Update
TMbuddy
Post by TMbuddy »
Target Users:
Users currently running TOS 6.0.500 or later versions.
Note: If your TOS version does not meet the requirements, please first check the update conditions for TOS 6.0.530.
Warning!
  • This version is not compatible with the Beta version's permissions.If permissions cannot be inherited after the update, you need to temporarily assign other permissions and then reset them to the ones you need.
Update Notes
Bugs fixed:
1. Fixed an issue that the MAC address was not returned for network ports without a connected Ethernet cable.
2. Fixed an issue that SMB failed to start in certain cases after reinstalling the system.
3. Fixed an issue that hidden folders were displayed when accessing via WebDAV.
4. Fixed an issue that the media index failed to index files starting with a dot (`.`).
5. Fixed an issue that the media index could not be enabled due to accidental corruption of the media index database.
6. Fixed an issue that errors occurred when executing the `VBoxManage` command.
7. Fixed an issue that an uninitialized USB drive could not be formatted.
8. Fixed an issue that the system could not join a domain in certain cases.
9. Fixed several other bugs.
What is new:
1. Added the `atop` command tool.
2. Added the macvlan network driver.
3. Optimized the configuration method for parameters when creating arrays.
4. Optimized the software list for `apt` commands to install and uninstall packages.
5. Optimized the logic for downloading and deleting logs in debug mode.
6. Optimized information in the system reports.
7. Optimized the display of certain languages in the system interface that the text was too long.
Important Information:
Update Procedure:
Other Software Downloads:
Download TNAS PC 5.2.003 for Windows OS:
https://download3.terra-master.com/Apps ... .2.021.exe
Download TNAS PC 5.1.202 for macOS (x86 and ARM architecture):
https://download3.terra-master.com/Apps ... .1.202.pkg
Download TNAS PC 5.1.202 for macOS (ARM architecture):
Download TNAS Mobile 3.3.027 for Android:
https://download2.terra-master.com/TNAS ... .3.027.apk
TNAS Mobile for iOS: Download from the iOS App Store.
liability
Australia
Re: TOS 6.0.577 (X86) is Released for Update
Post by liability »
liability wrote: ↑24 Dec 2024, 12:41 I updated two F2-221s about an hour ago, both updated with issues.
I meant to say that they updated WITHOUT issues. Don't seem to be able to edit my previous post.
DCCentR
Post by DCCentR »
Thanks for macvlan network driver ;)
Successfully upgraded from 6.0.555
F4-424 Pro
scout71
Italy
Post by scout71 »
But shouldn't the F2-221 be supported... did you install the 6,500 first and then this one without any problems?
Linuss
Italy
Post by Linuss »
liability wrote: ↑24 Dec 2024, 12:44
Hello, same thing with my F2-221. Everything seems to be working fine. Fingers crossed...
Linuss
Italy
Post by Linuss »
scout71 wrote: ↑24 Dec 2024, 17:43
with my F2-221 I started from 5.1.123. I then installed the beta 6.0.229 and from that I then installed 6.500.
Then the updates arrived automatically.
Linuss
Italy
Post by Linuss »
Linuss wrote: ↑24 Dec 2024, 18:38
Sorry, my bad. "the beta 6.0.229 and from that I then installed 6.500" not the 6.5, from 6.0.229 to 6.533, after that i had automatic updates and everything worked fine.
Beta 6.0.460 almost destroyed my NAS..
star
Sweden
Post by star »
t6-423,f8 ssd plus, f4-424 updated no issues
rfbjr
Post by rfbjr »
Been in the business too long to not update things a day before a holiday. I will update both of my NAS(es) ?? on Thursday. Enjoy all
F4-424 Pro (x2) and F6-424 at 7.0.1536
F4-425 Plus at 7.0.1422
D4-320 & D4-SSD
kai
Belarus
Post by kai »
Docker manager does not download images from the docker hub registry.
In fullscreen mode in the settings section, the text under the icons is shifted to the left.
