Mobile app crashes after logging in after TOS 6 upgrade
section94
Greece
Post by section94 »
What the title says. It used to work when I had TOS 5.1 but now both my Android phones with android 13 don't work any more. I log in with my credentials and after a few seconds the app just closes.
Tried installing older versions of the app but they say the NAS is not initialized (it certainly is). What can I do?
TMtina
Re: Mobile app crashes after logging in after TOS 6 upgrade
Post by TMtina »
section94 wrote: 17 Dec 2024, 02:39 What the title says. It used to work when I had TOS 5.1 but now both my Android phones with android 13 don't work any more. I log in with my credentials and after a few seconds the app just closes.
Are you upgraded your TOS to version 6.0.555? Is your LAN1 Ethernet port unplugged? Please insert an Ethernet cable into the LAN1 port and then reinstall the TNAS mobile app to try again.
section94
Greece
Post by section94 »
TMtina wrote: 17 Dec 2024, 10:17
That was it but....WHY? Whatever the reason I think it should be mentioned in the app somewhere, like a pop-up or something that you must use the LAN1 Ethernet port.
