I set up NFS on F8 Plus but was unable to connect.
syuheimurata
Japan
Post by syuheimurata »
TerrraMaster F8 Plus
TOS 6.0.555-00166
I have configured NFS on the F8 Plus.
I tried to connect from ESXi but was unable to connect.
I installed NFS Client on Windows and tried to access it, but got an error saying there was no path.
When I contacted TerraMaster's support, I was told that it was a firmware issue and I couldn't connect.
I bought this product to use NFS, so I'm looking for some kind of workaround.
Is there any way to avoid this?
syuheimurata
Japan
Re: I set up NFS on F8 Plus but was unable to connect.
syuheimurata wrote: ↑07 Dec 2024, 10:25 TerrraMaster F8 Plus
TOS 6.0.555-00166
https://photos.app.goo.gl/fR22y1oDZaJMAb6e7
https://photos.app.goo.gl/SXHmxQULDCTRcZo87
You might have encountered a known issue in TOS. As a temporary solution, you can try the method described here: viewtopic.php?p=40886#p40886.
This issue will be fixed in the next version. What actions did you take before encountering this problem?
syuheimurata
Japan
I'm not sure what specific input items to enter.
What ID is "folder_id from share"?
syuhei_murata@TNAS-F8:~# tersql -sql "delete from acl_host where folder_id not in (select folder_id from share)"
Its a structured query language (sql) command for a database. You enter it literally as shown (and as done it seems).
Frustrated Beta Tester!!!
syuheimurata
Japan
Thank you very much.
I appreciate it very much.
After running the command as is, I restarted the NFS service and was able to connect successfully.
Return to “File Services”
