Linux App not working
highgrade
Virgin Islands (USA)
Post by highgrade »
The Tnas Desktop app for Linux not is working not discovering my NAS I am Zorin OS
Re: Linux App not working
Thank you for your feedback! We will check and make the necessary adjustments. In the meantime, you can try the following methods:
1. Install TNAS PC using a Windows system.
2. Log into the router to view connected devices and their IP addresses.
3. Install the `nmap` tool on Zorin OS to scan the IP addresses of devices on the local network. Here are the steps to install and use `nmap`:
sudo apt update
sudo apt install nmap
nmap 192.168.1.0/24
# Adjust the IP range according to your network configuration
highgrade
Post by highgrade »
Still not seeing nas Via TNAS PC software please see attachment
EthanLiu
Post by EthanLiu »
highgrade wrote: ↑08 Dec 2024, 08:17
Recently, we have completed the adaptation work for the new version of TNAS PC on Linux systems. You can try downloading the installation package from the following link:
https://download3.terra-master.com/Apps ... _amd64.deb
If you encounter any issues during installation or use, please contact us immediately. We will conduct further adaptation and optimization work based on your feedback.
