F4 424 Pro CPU Temps
riff79
Australia
Post by riff79 »
Hi all,
Just a received a F4 424 Pro - but the CPU temps are really high hitting 90c constantly with the fan on FULL always.
I have change the power settings to:
Power limit 1: 13 000
Power limit 2: 30 000
Power limit 1 time window: 20
However its consistently at 90c - do I need more aggressive settings?
Also as a consequence the power brick is very hot. Is this normal? I don't think this unit will survive Australian heat at this rate....
Valnjes
Austria
Re: F4 424 Pro CPU Temps
Post by Valnjes »
Thats not alright.
On my F4-424 Pro, running DSM 7.2.2 Update 2, reported temperatures are 48°C at peak, mostly running at 38°C at idle.
riff79
Australia
Post by riff79 »
Valnjes wrote: ↑03 Dec 2024, 14:09 Thats not alright.
Thanks for that, seems like I need to do a factory optimal defaults in the bios.
Valnjes
Austria
Post by Valnjes »
I hope it fixes the temperature issue for you, because 90°C is too much.
Check if the fan is working, and if the enclosure is not tucked somewhere in a corner,
where it cant "breathe".
I will look into the termal-paste (or pad) of the TerraMaster, and replace it with my favorite paste for years - Artic Ceramique 2.
It does not have the best termals, but it last almost ferever, one of the best paste for long running hardware.
riff79
Australia
Post by riff79 »
Resetting the bios to optimal defaults fixed the issue - the CPU is now sitting in the 40c constantly, I have the fan on full, I'll see if I can have the fan on a lower speed as the next task.
Valnjes
Austria
Post by Valnjes »
And i will look to replace the fan with some Noctua fan, because i love good airflow and silence.
Just have to see if the pin-out of the TerraMaster fan matches the standard 4-pin layout.
I dont know why TerraMaster did not take the standard 4-pin connector like on any PC - it would be an easier way to replace the fan,
if it gets noisy or broken.
PS - The F4-424 has one fan header, the Pro version has two headers soldiered on the PCB, so i will if i can find the right connector to re-soldier my Noctua fan.
Valnjes wrote: ↑03 Dec 2024, 20:09
There have been a few posts on here regarding fan replacement and the appropriate wiring - but then @TM sometimes change things between models I suspect.
Valnjes
Austria
Post by Valnjes »
I can use my multimeter, because i only believe what i can measure. And the soldering iron will do the rest.
