I have added an anime library, pointed it to a folder that exists (I have it the same on a different plex server).
But clicking scan library doesn't seem to find the anime I have added.
Is there some post install process I need to have done?
Plex not displaying anything in library
Re: Plex not displaying anything in library
1.Verify Folder Permissions:
Ensure that the folder containing your anime files has the correct permissions set. Plex needs to be able to read the files in order to scan and add them to the library.
2.Check File Formats:
Confirm that the anime files are in a format that Plex supports. Commonly supported formats include MKV, MP4, AVI, etc.
3.You can also refer to the following link for the method to rescan again:
viewtopic.php?t=6868
Looks like it started working after tinkering a bit. I can't remember what I did!
- EthanBerg97
I have a F4-423, running TOS 6.0.650, and BIOS 5.19
I have used pretty much every guide I can find, set up a profile for plex, not set one up, used the app store version of plex, used a .tpk from plex itself; and I just can't get Plex to see any of the files and my libraries remain empty. What should i do ?
Works like a charm! Thank you!IrisLi wrote: ↑02 Dec 2024, 16:34 1.Verify Folder Permissions:
