Way to analyze drive space usage?
BigFatGuy
Post by BigFatGuy »
My drive space usage is higher than I expect... and my manual poking around doesn't show anything unusual.
I've got the recycle bin set to empty every week, and I've emptied it manually recently.
I have several shares, I don't really want to make a single share that encompasses everything on the drive so I can use the windows drive analysis tools.
Is there a way, in the TNAS control panel, to analyze drive space usage by folder/file type/etc?
TMnick
Re: Way to analyze drive space usage?
Post by TMnick »
BigFatGuy wrote: 01 Dec 2024, 08:58 My drive space usage is higher than I expect... and my manual poking around doesn't show anything unusual.
You can view the usage details by following these steps: Control Panel > Volume > more > Usage Details
And, when following the previous guidance, you find excessive usage attributed to "other", it will quite probably be 'Snapshots' of one form or another - possibly orphaned.
BigFatGuy
Post by BigFatGuy »
I don't have snapshots configured, but I did have Duple and some kind of Cloudsync set up for various experiments.
Looking at how long it's taking to uninstall cloudsync, this might be the issue.
Many thanks.
BigFatGuy
Post by BigFatGuy »
Just for my own edification, is there a way to get more granular information out of that "usage" screen? Something that will tell me what the 10G of data in "other" actually are?
IrisLi
Post by IrisLi »
BigFatGuy wrote: 02 Dec 2024, 04:27
Thank you for your feedback!
This requirement has been fed back to the product team and will be implemented in the future if it passes the review.
BigFatGuy
Post by BigFatGuy »
Thank you.
In the meantime: I've uninstalled all the un-needed backup utilities, but I still have 10G of "other" files that I cannot find or delete.
What is the next step to recover my empty drive space?
I don't the answer. I have more than that usage on most of my volumes. Should we really be worried about 10 or even 50GB in a total of multiple TB of storage?
IrisLi
Post by IrisLi »
BigFatGuy wrote: 02 Dec 2024, 20:55
Use tools like Putty to log in to the NAS command line terminal.
Link to guide:
viewtopic.php?t=2350
Enter the following command:
du -sh /Volume1/*
BigFatGuy
Post by BigFatGuy »
Gremlin wrote: 02 Dec 2024, 21:53 I don't the answer. I have more than that usage on most of my volumes. Should we really be worried about 10 or even 50GB in a total of multiple TB of storage?
I apologize. I typed badly.
10TB is tied up.
