Longer USB C Cable for D5-300C
mmurley3
Post by mmurley3 »
According to this thread, the D5-300C supports a 2 meter cable but requires an extension chip?
What's an extension chip? what cable works? One post says it shows a picture but there isn't one.
crisisacting
Re: Longer USB C Cable for D5-300C
Post by crisisacting »
It's likely in reference to being an active cable like this: https://tripplite.eaton.com/usbc-active ... U33005MC2C
TMpzhen
Post by TMpzhen »
mmurley3 wrote: 08 Nov 2024, 23:46
Yes, a 2-meter cable requires a signal amplifier chip, and we have verified that a 1.5-meter cable can be perfectly adapted.
mmurley3
Post by mmurley3 »
crisisacting wrote: 09 Nov 2024, 06:07
That's a 16 foot (5 meter) "power over USB C" cable?
crisisacting
mmurley3 wrote: 10 Nov 2024, 23:13That's a 16 foot (5 meter) "power over USB C" cable?
Regardless of the length, it literally says "data only" in the item title; plus you clearly didn't read the description of the product.
If you're this dense, it's pointless trying to help you.
Return to “USB Series”
