Conecting a domain to Terramaster f4-424
Daniil
Ukraine
Post by Daniil »
Hello, i have a error when connecting Terramaster f4-424 to domain, it shows an error - Impossible to use port 389.
Any ideas on how i can fix this please?
Re: Conecting a domain to Terramaster f4-424
Hi.
An identical case was received on the technical support mailbox, in Russian.
Is it you?
We are verifying the case you mentioned. We will inform you about the progress.
AlexHunta
Ukraine
Post by AlexHunta »
You still haven't given me an answer
Generally the domian server needs to be on the same network as the device.
When it says “Impossible to use port 389”, it means that the domain server cannot be accessed on port 389. We suggest you to check the domain server or network settings.
You mentioned “The domain server network address can be accessed.” May i ask from which network and by what means are you accessing the domian server?
tisiminina15
Belarus
Post by tisiminina15 »
Добрый день! Terramaster f4-424. Tos 6.0.535.
Не могу подключится к контроллеру домена. Пиши что неверное имя пользователя или пароль. хотя он верный 100%. в TOS 5 все работало. подскажите как мне подключится к домену??
так же ошибка при проверки почты.
Помогите пожалуйста разобраться с моими проблемами!
TMLila
Post by TMLila »
tisiminina15 wrote: 03 Dec 2024, 16:51 Добрый день! Terramaster f4-424. Tos 6.0.535.
Hi! Our lab has verified and reproduced the issue you encountered, and we are currently working on fixing it. It will be resolved in subsequent version releases. We look forward to your continued attention to our forum for update notifications.
tisiminina15
Belarus
TMQiuMoer wrote: 04 Dec 2024, 11:43
Добрый день! обновился до 6.0.555 . проблемы остались! (
ColaChen
Post by ColaChen »
We are currently fixing this issue. The version released on December 5th does not yet include a solution to this issue, and it will be resolved in subsequent versions. Thank you.
Return to “Privileges”
