- I have my Terra-master F6 server
- I have another server running Synology DSM
Test 1
Transfer from F6 to DSM (mounted as NFS Remote Folder within TOS 6)
Speed test for copying files - between 60MB/s and 70 MB/s
Test 2
Transfer from DSM to F6 (mounted as NFS Remote Folder within DSM)
Speed test for copying files - Between 100MB/s and 120MB/s
Test 3
Connect both servers using Rsync (using Duple Rsync task backup files from F6 to DSM).
Speed test for of backup - between 9MB/s and 10MB/s
The Rsync speed is very slow. I have 8TB of data to transfer via Rsync which would take over 9 days! The same transfer via NFS would take less than a day.
Questions...
1. Is this a limitation of Rsync?
2. Is this a limitation of TOS?
3. Is this a limitation of the F6 hardware?
I am going to try installing OpenMediaVault on my F6 and see if that shows any difference in Rsync speed. If it is faster I can assume the issue is with TOS.
