Guide 48GB RAM in F8 SSD Plus works great!
Hardware compatibility like hard drive, SSD, memory module, Wi-Fi adapter.
anuraj1
Post by anuraj1 »
I installed a 48GB DDR5 SODIMM (Corsair CMSX48GX5M1A4800C40) in my F8 SSD Plus and everything is working as expected. Just wanted to post this in case anyone wanted to try the same thing. The max listed in TM documentation is 32GB.
Images of System Overview:
Terramaster F8 SSD Plus
64GB RAM
8x4TB NVME
Re: 48GB RAM in F8 SSD Plus works great!
:?: But does it make it 'better' in any way :?:
F2-221 TOS7.0.1422 - 1x3TB Ext4, 1x4TB Btrfs
F2-425+ TOS7.0.1422 - 2x500GB nvme (P3) Traid, 2x6TB HDD (EXOS) Traid
anuraj1
Post by anuraj1 »
I don't know, I'm just enjoying tinkering right now since it's my first NAS :D
64GB RAM
8x4TB NVME
anuraj1
Post by anuraj1 »
I ended up installing Unraid last night and doing a pool of 8 ZFS SSDs. The extra RAM is great because Unraid runs in RAM and ZFS uses RAM.
64GB RAM
8x4TB NVME
jdesbonnet
Ireland
Post by jdesbonnet »
Issuing a dmidecode command on my F8 SSD Plus device reports that up to 64GB is supported in theory. I can see there are 48GB SODIMM modules on the market, but I can't find anything of larger capacity.
I wonder can Terramaster confirm there there are no issues with a 48GB module? I'm reluctant to purchase an oversized module without some informal confirmation that it has a decent chance of success.
dmidecode -t 16
# dmidecode 3.3
Getting SMBIOS data from sysfs.
SMBIOS 3.5.0 present.
Handle 0x003B, DMI type 16, 23 bytes
Physical Memory Array
	Use: System Memory
	Error Correction Type: None
	Maximum Capacity: 64 GB
	Error Information Handle: Not Provided
	Number Of Devices: 2
In the official parameter information released by Intel, this CPU supports up to 16GB RAM. 64GB is the maximum RAM that the motherboard system can support.
We found that 32GB of RAM is also supported after a long period of testing in our labs.
As for higher RAM capacity, we have not actually tested it for the time being. So we can't guarantee that 64GB RAM is available.
anuraj1
Post by anuraj1 »
jdesbonnet wrote: ↑27 Oct 2024, 20:24 I can see there are 48GB SODIMM modules on the market, but I can't find anything of larger capacity.
I don't think 64gb DDR5 SODIMMs have been released yet.
FWIW, the 48gb in my F8 SSD Plus is working really well.
64GB RAM
8x4TB NVME
jdesbonnet
Ireland
anuraj1 wrote: ↑30 Oct 2024, 01:07
Thanks for that report on the 48GB SODIMM. Based on your good experience I think I'll order the same SKU of 48GB module. 48GB opens up some interesting server applications with docker.
On a related topic, I've only had my F8 SSD Plus for a few days so still feeling my way around, I'm trying to figure how to configure more paging space (it has defaulted to only 2GB). Looks like the BTRFS file system doesn't support swapfiles :/
anuraj1
Post by anuraj1 »
jdesbonnet wrote: ↑30 Oct 2024, 05:18 Looks like the BTRFS file system doesn't support swapfiles :/
I really liked TOS6 but I ended up installing Unraid in order to get more features like you're looking for.
64GB RAM
8x4TB NVME
jdesbonnet
Ireland
A quick update. Based on anuraj1 's good experience with a 48GB SODIMM modules, I purchased the same module and it works perfectly. Did a memtest which passed, and it's been running without issue for several days. Part Number: CMSX48GX5M1A4800C40. This really turns the little NAS box into a rather capable home server for me.
I've appended the memory module part of dmidecode information below:
Handle 0x003C, DMI type 17, 92 bytes
Memory Device
Array Handle: 0x003B
Total Width: 64 bits
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: Controller0-ChannelA-DIMM0
Bank Locator: BANK 0
Type: DDR5
Type Detail: Synchronous
Speed: 4800 MT/s
Manufacturer: Corsair
Serial Number: 00000000
Asset Tag: 9876543210
Rank: 2
Configured Memory Speed: 4800 MT/s
Minimum Voltage: 1.1 V
Maximum Voltage: 1.1 V
Configured Voltage: 1.1 V
Memory Technology: DRAM
Memory Operating Mode Capability: Volatile memory
Firmware Version: Not Specified
Module Manufacturer ID: Bank 3, Hex 0x9E
Module Product ID: Unknown
Memory Subsystem Controller Manufacturer ID: Unknown
Memory Subsystem Controller Product ID: Unknown
Non-Volatile Size: None
Volatile Size: 48 GB
Cache Size: None
Logical Size: None
Return to “Compatibility”
