Plex "configuring" after hitting reset
jkd3777
Post by jkd3777 »
I am using an F4-210 4 bay quad-core 1.4GHz, 1GB DDR Terramaster NAS
I was using the Desktop TOS interface and was opening my Plex app and I selected reset instead of enter. Now Plex has been "configuring" for hours. Is this normal and/or do I need to continue to just wait? Image
Re: Plex "configuring" after hitting reset
You can try to clear the Plex configuration by manually deleting the files under File Manager > User > plex.
If this does not help, you can check for file system errors or try to reset the TOS to fix the system errors.
viewtopic.php?t=2575
viewtopic.php?t=423
Return to “Plex Media Server”
