zero notifcation of drive failing
- firedrakes
second time this has happened.
where system give zero notification on a drive issue.
Until i go to storage pool page on os.
Re: zero notifcation of drive failing
We know that you are using F4-210 TOS 4.2.x.
We will keep an eye out for and avoid possible similar problems in future and other TOS releases.
- firedrakes
k . so its a known issue on my model then?
seeing am now moving all data off the device.
going forward it will be nothing more then a temp data nas.
This is an unknown issue that we still need to verify.
- firedrakes
still concerning that you knew model. when i ref the issue
Not really. You mentioned it in a previous post.
(and it is something support people like to know so they don't have to read every previous post to find out.)
Frustrated Beta Tester!!!
- firedrakes
ah.
anyhow yeah. i dont trust this model of nas anymore.
i was wondering why it keep going on deep discount sale on amazon...
anyhow i switch all data on a better manf of nas.
Generally, for any piece of tech, take a quick look on Ebay and see which models are being sold off 'used'. They are, inevitably, the unpopular ones or the ones that have been superceded or are just relatively 'old tech'.
- crisisacting
- Silver Member
They literally just checked your post history to find that info
You bought the cheapest model from TerraMaster & likely just as realtek dropped support for its SoC, so with the worst timing.firedrakes wrote: ↑01 Sep 2024, 03:25 … i don't trust this model of nas anymore.
anyhow i switch all data on a better manufacturer of NAS.
If you'd put the same effort you are doing so now, by making inquiries, you'd likely have bought an ×86/×64 based NAS with wider and even alternate support options, so you weren't stuck.
“Better manufacturer” is only going to hold true that's followed through with support and standing behind their product(s).
None of these NAS manufacturers put much attention into their entry level consumer offerings; it's their higher models or commercial products into which they actually throw resources.
- firedrakes
bulk storage usage. nothing else. that all it used for. this was in covid times to.crisisacting wrote: ↑02 Sep 2024, 04:57They literally just checked your post history to find that info& you didn't correct them if that's changed since those previous posts.
but it does seem this model had a issue and they simple stop manf after og stock was made.
