I have WOL enabled in Bios and TOS, in TNAS for PC i see wol activated and no matter i do i can't get divice to start.
I'm Using wakemeonlan
Do i need to configure something more on F4-423 or in the router?
Thank you
Rui
Can't get Wol to Work on my F4-423 no matter what i do
Re: Can't get Wol to Work on my F4-423 no matter what i do
TOS Version??
Please refer to the method in the following link:viewtopic.php?t=5939
- adviserjury
Thank you, I'm looking for itTMnight wrote: ↑09 Aug 2024, 18:12Please refer to the method in the following link:viewtopic.php?t=5939
adviserjurygeometry dash
Did you find an answer?
This may help (or not
I have both 'Wakemeonlan' and 'WakeOnLan' On my network. If I scan the segment I find that both modules will give me:
Lan1 on F5-221 (Primary LAN in bonded link) but not LAN2 (subsidiary LAN in bonded Link)
LAN2 on F2-424 (backup lan in passive bond) but not LAN1 (Primary LAN)
Sending WOL to LAN2 works on F2-424 even though it should not according to the advisory messages (Only works on LAN1 in Bonded Link)
Both 221 & 424 are currently running Tos5.1.145
Make sure you are scanning correct network segment. In WakeMeOnLan this appears to change to default on every start. {I did a full delete and re-scan to be certain}.
WOL from TNAS-PC appears to work as expected as well.
I am not able to test the F5-221 as it's 'working'.
