Each attempt to start this NAS ends with: "udhcpc: no lease, forking to background".
What should I do to solve the problem?
F2-423 start problem
Re: F2-423 start problem
Not exactly my field but I would suggest checking your network.
a) Are you requesting an IP address from dhcp?
b) Have you set an ip address in the nas?
c) Do you have a dhcp server on your network? (Like your router) and is it working?
d) Do you have any other devices on the LAN that can issue dhcp addresses:
{Devices such as TPLink powerline adapters can have an unseen bug that enables them as alternate dhcp servers in the event no other server can be found. Later firmware updates have been issued (in some cases) that makes this option visible and modifiable.}
'dnsmasq' is also involved.
Maybe the router has not assigned an IP address. You can try restarting the router.
Based on the screenshot, the IP addresses being used are defaults assigned by the nas when it does not get an ip from the network. There is almost certainly an issue with the router/network. Do you have other devices attached and do they get ip addresses? Is the DHCP address pool set up correctly? Are the cable(s) between router/nas ok?
{By the way, when first installing TOS only have LAN1 connected.}
I have other devices, but they successfully connected by WiFi.Gremlin wrote: ↑27 Jul 2024, 16:57 Based on the screenshot, the IP addresses being used are defaults assigned by the nas when it does not get an ip from the network. There is almost certainly an issue with the router/network. Do you have other devices attached and do they get ip addresses? Is the DHCP address pool set up correctly? Are the cable(s) between router/nas ok?
At the same time tried to connect my laptops on this cable - all OK.
Unfortunately I can't tell if the address pool is configured correctly, I don't know much about network settings.
I tried both LAN ports
Probably DHCP is working correctly, here are the router logs after rebooting NAS:
2024-07-27 13:32:39 [Debug][Debug-Log] static:[dhcpd]receive Discover, xid[4aed5675], mac[6c:bf:b5:03:da:6b], option60[udhcp 1.35.0]
2024-07-27 13:32:39 [Critical][Debug-Log] static:[dhcpd]xid[4aed5675] choose [main] address pool
2024-07-27 13:32:40 [Debug][Debug-Log] static:[dhcpd]send Ack, xid[4aed5675], mac[6c:bf:b5:03:da:6b], request serverip[192.168.100.1], yourip[192.168.100.8], dns1[8.8.8.8], dns2[8.8.4.4]
What's strange is that only one line "no lease" after that.
Dear friends, thanks for all your advices, the problem is solved. Most likely it was a few calls to the Internet provider and setting up the router that helped. And a DHCP tuning.
Now I'm moving on to the stage of system installation.
Learned a lot about the unit even before it was first run
Have a nice day!
Have a nice day!
Glad to here it. Good Luck
