download_dir directory: /public error accessing for both SABnzbd and Nzbget
Discussion about Docker
octavious19
Post by octavious19 »
Hi All,
I'm having trouble assigning the download directory for my Nzbget and SABnzbd. It keeps giving me this error in both dockers:
I've read that I just need to give this directory permissions to access it, and I think I've done that, but it still doesn't work. So I must be doing it wrong. Can anyone help me out?
Thanks in advance!
Re: download_dir directory: /public error accessing for both SABnzbd and Nzbget
Is "/public" your host directory (TOS directory) or container directory?
If it is your host directory, then it is the wrong path. The correct path should be:
"/Volume1/public" (TOS5&6)
"/mnt/md0/public" (TOS4)
octavious19
Thanks for the quick reply!
I have changed the host directory to how you said, and then in SABnzbd I made the directory /download, but now when I finish downloads, I can't find the files I downloaded anywhere. Also, I think it's still not downloading with the correct drive. The download speed is maxing out at 100 mbs, and that is my external hard drive that has those read/write limitations. I want to use the internal M2 SSD hard drive that can keep up with my internet speed at 200 mbs. But more importantly, I need to find where the files went. I did a search in the file manager for those files, and still couldn't find them.
Thanks for your help!
Since you created the /download folder inside the container, you will of course not be able to find it from the TOS system.
You can edit the container to create another directory relationship:
Host directory: /Volume1/ any directory you specify (X)
Container directory: /download
In this way, you can access /download in the container through the directory X.
octavious19
That worked. Thanks for your help!
Return to “Docker”
