Nextcloud Trusted Domains
Timee2k3
Germany
Post by Timee2k3 »
Hello , i have a problem. I want to Put my dyndns Adress to my config.php. but i cannot find the File . Can Somebody Help me.
Re: Nextcloud Trusted Domains
You can open the command terminal via SSH/Telnet tool and look for the file you need from the following directory.
viewtopic.php?t=2350
TOS 4 NextCloud app location: /mnt/md0/application/web-ext/nextcloud
TOS 5&6 NextCloud app location: /Volume1/\@apps/Nextcloud/
Timee2k3
Germany
Post by Timee2k3 »
Thank you,
Should i have a Admin User to See the config File ? He Said no Sudo User already.
Timee2k3
Germany
Post by Timee2k3 »
There ist ONLY a config ini in this folder . How can i open thé File to change it
Timee2k3
Germany
Post by Timee2k3 »
When i type sudo -i He say unknown User ...
The login methods for different TOS versions of command terminals are different.
If you are using TOS5 or TOS6, the user you have successfully logged in to is equivalent to root.
You can use the vi command tool to open and modify this file. Or a simpler method is to log in and modify through the SCP GUI tool.
Return to “Others”
