Mobile App 2.3.23 problem
Jonas Pi
Post by Jonas Pi »
Hey there,
I was updating TNAS Mobile App from 2.3.16 to 2.3.23
The new Version (2.3.23, downloaded from inside the app - settings/version information/download ) won't recognize any of my user and i can't log in.
Everytime i try there's the message that my User or Password is incorrect.
If i uninstall the app and install the 2.3.16 (Android Playstore Version) again it works fine.
Please fix it :-)
Sincere
F4-210
Re: Mobile App 2.3.23 problem
Thank you for the reporting.
Please advise whether there is any special characters in your password. We will check here.
Jonas Pi
Post by Jonas Pi »
Good Evening,
Some capital letters, symbols and numbers. I can tell you the symbol is a plus (+)
Thanks for the reply!
Sincerely,
Jonas
F4-210
Thank you for the feedback. We have tested here that password with symbol + would not be accepted by TNAS Mobile 2.3.23.
Jonas Pi
Post by Jonas Pi »
Thanks for testing!
Will it be fixes within the next releases ?
Sincerely,
Jonas
F4-210
This issue has been reported to the tech team, I think they will fix it, but I can't tell when. Will keep you updated.
Jonas Pi
Post by Jonas Pi »
Hey there,
i guess the problem is fixed. I'm not quite sure if my Smartphone was updating your app, but i've done a TOS update too so either of that fixed the issue, the special sign plus (+) is working in my password again.
Thank you!!
Regards from Germany :)
F4-210
Thanks for the feedback and glad to know it's fixed now.
