how to start over with data?
TerraMaster Snapshot is a disaster recovery tool developed based on the BTRFS file system.
jwills70
Post by jwills70 »
ok i done a snapshot recovery which is currently being recovered and I am dragging all my files of my nas to USB drives attached
when it started to do the recovery it appears to have split my tnas 130tb into 2 parts
1 part has my files on around 100tb
2 part spare space where my files are being recovered to 30tb
so once its done I want to start over and create a new volume (delete whatever left) so I have my 130tb back not just the 30tb I can currently excess
my next question is this once done I going to want to go back to the start re rebuild my nas storage so I have the full 130tb again not just 30tb that's showing
how do I go about deleting the hard drives and then rebuild the pool ??
do I just delete the volume ??
or do I delete the hard drives
also will this delete the tos ??
if so how do I reinstall it ??
jwills70
Re: how to start over with data?
Post by jwills70 »
I'm not sure if this is relevant to your situation but if you have a snapshot of 'data', the 'data' is not copied or stored in the snapshot. But, If the 'data' is then deleted, the data space is not cleared/released back to the file system - it is merely reallocated to be part of the snapshot. If you copy a snapshot file to another medium it will replicate the full data as it was at the time of the snapshot. If you analyse the file system space via control panel
{Control Panel > Volume > Select > More > Usage}
you will see space allocated to 'Others' which is where snapshots live. As I found, to my cost, this occupied space rapidly increases with multiple snapshots and frequently changing data. And, if for any reason, snapshots are 'lost' but still on the drive(s), it can be a tough time to find them again and get rid of them because they are write protected (even from super admin user).
Hope that helps.
jwills70
Post by jwills70 »
Gremlin wrote: 27 May 2024, 01:37 I'm not sure if this is relevant to your situation but if you have a snapshot of 'data', the 'data' is not copied or stored in the snapshot. But, If the 'data' is then deleted, the data space is not cleared/released back to the file system - it is merely reallocated to be part of the snapshot. If you copy a snapshot file to another medium it will replicate the full data as it was at the time of the snapshot. If you analyse the file system space via control panel
Hope that helps.
ok my others currently shows 111.26tb others space being used
so are you saying if I delete the snapshots the space will come back ?? if so that would be great
once I have all my files I need that is
or how will I get the space back there's got to be some way
Because of the changes that have occurred in your system I would not like to answer that. But, now you know why the spacce has been used up, hopefully @TMSupport may be able to offer some insight. (Might help if you could show snapshot lists.)
jwills70
Post by jwills70 »
Gremlin wrote: 27 May 2024, 06:33
@TMSupport
have attached picture of snapshots its currently still restoring
We are not 100% certain of the situation from your description.
Regarding files that have been taken snapshots, as long as any related snapshots still exist, the files will continue to occupy space unless all related snapshots are deleted.
Generally speaking, when restoring a snapshot, the final capacity will not be greater than your volume capacity itself, but for proper use, it is still recommended to reserve some space. If you want to free up more space, you can consider deleting individual unwanted snapshots.
If this still does not answer your questions, please continue to ask under the original topic.
viewtopic.php?p=35498#p35498
Return to “Snapshot”
