BackBlaze B2 Synce keeps saying operation failed.
hamburgernet
Post by hamburgernet »
Every time I try to connect my account it says "operation failed". I then have to recreate a new application key to try again as it seems to keep the old one somewhere, even after reinstalling. I've tried creating different application keys on BackBlaze, uninstalling, and restarting and nothing works. All the other post seem to be dead ends. Anyone know how to fix this?
TMlinda
Re: BackBlaze B2 Synce keeps saying operation failed.
Post by TMlinda »
hamburgernet wrote: ↑16 Apr 2024, 20:56
Are you using the CloudSync application? What is the application version? Check if the TNAS network is connected.
This may help you solve the issue:
login in SSH,input the following instuction:
viewtopic.php?t=2350
ter_curl --insecure -o /etc/ssl/certs/ca-certificates.crt https://raw.githubusercontent.com/bagder/ca-bundle/master/ca-bundle.crt
hamburgernet
TMwuu wrote: ↑16 Apr 2024, 21:57
Im using BackBlaze B2 Sync version 2.0.11. Stupid question but how would I check to see if it has a connection?
TMLyy
Post by TMLyy »
hamburgernet wrote: ↑17 Apr 2024, 21:21
Is your NAS network working properly? Please check if the key is filled in correctly and provide a screenshot of the operation failure.
hamburgernet
TMLyy wrote: ↑17 Apr 2024, 22:12
From what i can tell its connected to the internet.
Return to “CloudSync”
