login error
Captmo
login error
Post by Captmo »
the TNAs is a f2 210 with 2 drives installed
I can see the device in the TNAS software ok
I can see the ipaddress
i can change the ip address
I can see the files on the TNAS and download them
if i choose login I get an error
Warning: copy(./js/jquery.js): failed to open stream: No such file or directory in /opt/var/index.php on line 4
no idea whats happening here ?
I have installed
Re: login error
It seems that there is an unknown error in the file related to the webpage.
In response to this situation, troubleshooting is quite difficult. You can consider reinstalling TOS to reset the configuration that may have errors:
viewtopic.php?t=423
Return to “Network”
