Tnas online issue
[email protected]
Tnas online issue
Post by [email protected] »
I have remote login sesion Tnas.online setup correctly. Now always appear ID State connecting, I was using Global (Recommended) because I am from Spain. Somebody can say me what is the issue. Is the Global service down? I can to do it from China server.
thanks
Re: Tnas online issue
Hi, please advise your TNAS model number and current TOS version in return.
Was it working before?
Please uncheck "enable TNAS online remote access - apply and re-enable it again to see if it could be registered.
We will check the global server here again.
[email protected]
Thanks for your quick answer
Nas model F2-221
TOS version 4.1.24
Yes it was working fine until yesterday. I disabled and enabled sometimes but the issue is the same. Over Global Server always say Connecting. I can connect over China server but the recommendation for Non chinnese users is use Global
In advanced thanks
Hi, did you try again ? Is it ok now?
Return to “Network”
