NUT UPS configuration
fedex03
Post by fedex03 »
Hi there,
I have my UPS connected to a server running NUT to get information form my UPS.
I'm looking for a guide to configure my F2-424 to read UPS information from NUT.
In the Hardware and power configuration I enabled the "UPS Support" and selected "TNAS UPS server" as UPS type, but I cannot access to the UPS information.
Any help?
Thanks in advance for your help!
Re: NUT UPS configuration
Presume you input server ip into TNAS setup.
Configuration of TNAS is limited (to none existent) for NUT. You may be better off setting up TNAS as server (with UPS connected to TNAS via USB) and then point the server at the TNAS.
Frustrated Beta Tester!!!
If not mistaken and remember correctly, UPS function on TOS is based on NUT.
Here is working fine, standard setup in TOS:
And here the config of NUT server running on HomeAsistant machine with UPS connected to it.
fedex03
Post by fedex03 »
outkastm wrote: ↑30 Jan 2024, 15:17 If not mistaken and remember correctly, UPS function on TOS is based on NUT.
Thank you for the reply.
I configured the NUT as you, the only difference is the user.
I defined the following users:
  • upsadmin
  • upsmaster
  • upsuser
Maybe this is the cause.
Let me try to add the user like you.
Thank you!
