Purchase a replacement fan for F4-423
Do any one know were I could purchase a replacement fan one of my fans wire is broken I had to reconnect it use black tap to secure it together I will like to just replace the fan Device is F4-423
Re: Purchase a replacement fan for F4-423
If your fan uses an XHP-4 connector like this:
you are probably out of luck. TM said in another post they don't sell them!
Just repair the wires properly if the fan is still good. Else, buy a fan of your choice and rewire the connector.
There are appropriate posts on this forum.
{Otherwise check motherboard. Some come with "standard" fan connectors which may be functional. My F5-221 has additional standard connectors, my F2-221 does not.}
Frustrated Beta Tester!!!
I recommend you contact the service team for a warranty service.
