Cloudsync not working
spligosh
Post by spligosh »
I managed to get this working initially but now I can't get it to work at all. I can install the software but then I get presented with a dialogue box with, for instance, dropboxsync1 -and when I click on next nothing happens at all! Any suggestions. I've tried uninstalling and reinstalling many times. I've rebooted and restarted everything without success - help please!
Re: Cloudsync not working
The Cloudsync app has been removed from TOS Application center already, it's suggested to install and use the independent apps such as Google Drive sync, Dropbox sync.
spligosh
Post by spligosh »
These behave in exactly the same way?
Yes.
spligosh
Post by spligosh »
No - you misunderstood
These apps don’t work in the same way as the cloud sync app didn’t work!
spligosh
Post by spligosh »
Does no-one know how to fix this - the storage apps - Google Drive, Dropbox etc just don’t work!
You need to check your network settings and firewall. Make sure IP, DNS, all settings are correct. Google drive sync and dropbox sync are popular app, we did not receive report app fails before except of OneDrive sync, but that has been fixed.
Return to “CloudSync”
