Why Is A-USBLAN-2.5G Not Recognized on TNAS Devices?
About TNAS hardware
Symptoms:
A-USBLAN-2.5G (USB 2.5G Dongle) is not recognized when connected to TNAS devices, but it is recognized when connected to a PC.
Applicable Models:
A-USBLAN-2.5G
Solution:
Using the example of a Win10 system:
1. Connect the A-USBLAN-2.5G adapter to your PC and go to Device Manager > Network Adapters to check for the USB 2.5G driver.
2. Download WIN_USB_PGTOOL_v2.0.13 burning tool and run RtPGtoolUI.exe
https://download3.terra-master.com/Util ... .13_V3.zip
3. Configure the PGtoolUI interface:
3.1 Fill in CURRENT, MINIMUM, and MAXIMUM with the MAC address you need to burn.
3.2 Check SPI_FLASH_EN, EEPROM_EN, LINK_OK.
3.3 Set LED_SEL_CFG to 200008003F020200.
3.4 Keep other options at their defaults.
3.5 Click "Program" to burn.
4. This is the interface for burning completion. After the burning process is completed, please remove A-USBLAN-2.5G from the PC and connect it to the TNAS device for use.
crisisacting
Re: Why Is A-USBLAN-2.5G Not Recognized on TNAS Devices?
Post by crisisacting »
The burning tool download is not linked in your post.
SteveEtho
Post by SteveEtho »
Awesome so glad I stumbled onto this! Finally my Terramaster 2.5G USB adapter is detected and working on my F5-221 running TOS6, thanks for this.
LordP
Post by LordP »
I tried this, but everything is greyed out.
I am on Windows 11 and ran RtPGtoolUI.exe as administrator.
I do see the unit with the tool and in Device Manager, but I cannot change any parameters.
Any ideas why?
Thank you.
F4-423
TOS version is 6.0.694
BIOS is 5.19
Hard drives 4x ST24000NT002-3N1101 24TB Iron Wolf Pro
TOS - Crucial P310 4TB PCIe Gen4 2280 NVMe M.2
Hypercache - Crucial P310 4TB PCIe Gen4 2280 NVMe M.2
OWC 32GB (2x16GB) DDR4 3200 PC4-25600 CL22
crisisacting
LordP wrote: ↑22 Aug 2025, 21:33 … Any ideas why?
This tool doesn't work in Windows 11; you'll need to run it under Windows 10 to apply it.
LordP
Post by LordP »
crisisacting wrote: ↑23 Aug 2025, 03:38
Oh. I guess I'll have to create a virtual machine.
Will that work?
F4-423
BIOS is 5.19
LordP
Post by LordP »
Well, I found a newer version of the tool: WIN_USB_PGTOOL_v2.0.19
And it does allow me to change SOME things, but not all that are illustrated here. For example, EEPROM_EN is selectable, but LPM_EN is not selectable.
I think I'll leave well enough alone and just forget about this tweak.
Thanks for your help.
F4-423
BIOS is 5.19
Return to “Hardware”
