After upgrade to 5.1.40 for unknown reason no access to SMB shares and no remote access via SSH
las68
Post by las68 »
TOS_X642.0_5.1.40, U2-233
After upgrade to 5.140 stops access by SSH (while service is enabled and configured), and no any access by SMB to shares.
Cold reboot restores access by SSH and SMB shares, but this is no good.
Re: After upgrade to 5.1.40 for unknown reason no access to SMB shares and no remote access via SSH
There is no such TNAS model like U12-322, are you referring to U12-322-9100?
You seem to have used TOS4 before? If so, your storage structure cannot meet the new TOS5 version, we recommend you to keep using the previous version:
Install TOS 5.1.24
https://download2.terra-master.com/TOS_ ... 221846.ins
If you want to use the new TOS5 version, this may be a troublesome operation step. You need to back up the data after installing TOS5.1.24, reset the hard disk, and then reinstall TOS. For detailed steps, please refer to:
viewtopic.php?f=28&t=4912
I guess the correct model name is F2-223.
las68
Post by las68 »
Sorry, this is U12-332. but problem with occasional no access to ssh and smb still exist.
Is there a way to catch the root of evil ?
Based on the known information, the problem cannot be identified yet. It is recommended that you collect a system report from "TOS Technical Support Report Issues" and send it to the technical support email for analysis through network disk shared link.
Return to “System Update”
