So what are the conditions for the fan to start spinning and when does he stop?
Right now I have problems with these two models
WDC_WD80EMZZ-11B4FB0 and
WDC_WD80EZAZ-11TDBA0.
On the first one the led lights up when accessed and the fan rotates. On the second one the led does not light up and the fan also stays off.
hd-parm -C <disk>Code: Select all
drive state is: standbyCode: Select all
drive state is: active/idleI have set up via hd-idle to spin down after a certain time.
Thanks a lot
