TNAS desktop app problem
jd3wolfe
Post by jd3wolfe »
Installed and re-installed desktop app but it doesn't appear to be opening properly. It searches and finds the device but nothing else. Hard to explain so I will attach screenshot. Windows 11. F2-210.
Web application works fine.
TMlinda
Re: TNAS desktop app problem
Post by TMlinda »
{L_BUTTON_AT}jd3wolfe
What version of TANS PC are you using? You can go to the official website download center to find and update to the latest version before trying to search.
You are using a TNAS PC version that is not compatible with your device.
Please download the TNAS PC version compatible with your model here.
https://support.terra-master.com/downlo ... uct=F2-210
https://download2.terra-master.com/Terr ... .2.0.6.zip
Return to “Initialization”
