USB drive not mounted at startup
dotdotdot
Post by dotdotdot »
I have a F2-221 with TOS 5.1.33 , MAPL304V17,
When I start my F2-221, the USB drive is not mounted at startup. After switching on, I must plug it in and then, it is displayed.
I wish the USB drive would be automatically mounted at startup.
What I have done: I tried to plug in several external drive (Seagate, WD) same problem. I have resetted my terramaster and locally reinstalled TOS 5.1.33 and I faced the same problem.
I have formatted the external USB HD drive using TOS in Ext4, it changed nothing.
i have logged in via ssh and checked fdisk -l and found the attached USB drive (but it was not mounted)
So i manually mounted it using
mount -t ext4 -o rw /dev/sdd1 /Volume1/@usb/usbshare1
The network share appears but in the TOS, I can't see the USB drive icon at the top, so i can't remove it from the TOS.
I wonder if this problem is only mine or if it a normal behavior of Terramaster NAS. Are your USB drives auto mounted at startup or are you obliged to mount it manually after it started up?
It is a major problem in case of power failure.
Re: USB drive not mounted at startup
Hi. Do you have encryption enabled on the USB device? When encryption is enabled, it will not be automatically mounted when booting.
dissidence
Post by dissidence »
i am having this issue too, after a reboot i have to manually unplug and plug them in to see them again.
is there a setting that i am missing?
but ya, this is a little hard to fix if i am away from home and there is a power failure.
Try 5.1.34, does this issue persist?
dissidence
i will try that once the update package is available for download, this is not a new problem for me.
now if i can only get it to resize the storage pool to fit the new hard drives.
