TNAS Mobile 3 "Conection lost, please log in again"
fmattbp
Mexico
Post by fmattbp »
TNAS F4-421
Recently upgraded to 5.1.33-00360
TNAS Mobile 3.1.6
Every time I try to log in a error message displays "Conection lost, please log in again". The "Force redirection from HTTP to HTTPS connectios" option is disabled, in the mobile application no matter if I try with HTTP (port 8181) or HTTPS (port 5443) it keeps displating the same error.
Any other configuration that should I check?
Re: TNAS Mobile 3 "Conection lost, please log in again"
Are you using the TNAS.online link to connect or use the Internet IP/DDNS domain name + mapped port to connect?
If you use TNAS ID.tnas.link\TNAS ID.cn.tnas.link\TNAS ID.us.tnas.link\TNAS ID.eu.tnas.link to connect, you don't need to fill anything at "port" box.
fmattbp
Mexico
Post by fmattbp »
TMzethar wrote: 24 Apr 2023, 18:58 Are you using the TNAS.online link to connect or use the Internet IP/DDNS domain name + mapped port to connect?
I'm using the IP address to log in. I don't have enabled the remote login with TNAS ID, I would prefer the IP method to keep remote login disabled.
Return to “Network”
