4 digit Verification code after 3 failed logins
PhilJG2021
Post by PhilJG2021 »
After 3 failed logins to TOS the login screen shows a 4 digit verification code as extra while logging in.
I attempted login and input the 4 digit verification code but a message flags up thatr the code is incorrect.
a\am \i doing something wrong? TOS5
Re: 4 digit Verification code after 3 failed logins
Hi, the CAPTCHA code help to prevent excessive illegal login attempts. there is nothing wrong here except that you typed an incorrect CAPTCHA code. The code symbol is difficult to be recognized, you can click on the symbol to refresh it until you find one that is comfortable for you to read.
Brodieman
Post by Brodieman »
I know this is old but I am having the same issue. I can assure you that the code is correct yet it's saying it's not.
Brodieman
Post by Brodieman »
I attached a screenshot, this is clearly 9283 yet it says that is wrong
Invariably I cannot read the code and have to enlarge the screen. Then, inevitably, it does not work.
PhilJG2021
Brodieman wrote: 06 Dec 2023, 22:11 I attached a screenshot, this is clearly 9283 yet it says that is wrong
I'm having the same problem at the moment
PhilJG2021
Not accepting displayed verification code
Please clean your browser cache, restart your TNAS and try again.
gintasc
Post by gintasc »
same problem here, i certainly entered a correct code, but TNAS says it"s incorrect. The extra security step from TM is welcome, but only if it works as intended. Frustrating... to say the least
gintasc wrote: 02 Aug 2024, 08:45
Click the verification code to refresh new code.
Return to “Security”
