Users/Support --
The installed SSL cert on my TM expired in 2015. Please advise how to install a new one. I've got ssh access into the box so if nothing else, please tell me where the current cert is housed. Thanks.
SSL Cert expired in 2015 - need option to install a new one
Re: SSL Cert expired in 2015 - need option to install a new one
Please advise your current TOS version and please go to TOS Control panel - General Settings - Security -SSL certificate, and click "Generate new certificate & key" as the following picture shows.
![Image]()
I'm on 4.1.18-2001031451
I did find the Ctrl Panel/Settings/SSL cert and did the regen. See screen cap.
However, when I ftp in (FileZilla, latest version) I still get the 2015 cert. Thoughts?
This is a self-issued certificate. We will look into the case, if there is something wrong there, we will resolve it in next version.
We have double check on the certificate, but did not find anything wrong here.
would you send your certificate to support(a)terra-master.com? we would like to check what is wrong inside this one.
