I bought my F2-220 on Amazon and as of today, maybe earlier this week (not entirely sure) I noticed I was no longer able to access the device on the network. I turned it off, turned it back on, and it just doesn't load up. No lights indicating LAN is working, all the HDD lights are red, the power light is green.
I took the drives out, tried to power it back up, same thing, all HDD lights red, no LAN light, and power light is green. Tried a different port on the switch, tried a different network cable, nothing works.
Any help would be greatly appreciated.
F2-220 - LAN Light isn't on, device not accessing network
TMAY
Re: F2-220 - LAN Light isn't on, device not accessing network
May I ask if the TNAS PC can search for the nas when the empty machine is turned on?
Your init boot internal USB might have gone bad. I've had this happen with 2 of my f2-221's. Burned new high quality "fit" size USB keys and all went back to normal.
Thank you for your answer @titanrx8,
When you say "to burn a new hight quality fit size usb key", is there a tutorial about it? Or just I have to download an image of the TOS operative system and to burn it in a usb key? Do I have to unmount the case of the NAS?
Please refer to the article to burn a USB initboot.
viewtopic.php?f=76&t=1455
