Can't expand volume after adding drive to RAID 5 storage pool
zathrath03
Post by zathrath03 »
I added a fourth HDD to my RAID 5. The storage pool correctly increased for the added drive. However, when I attempted to expand the volume, the volume capacity is grayed out.
Any ideas on how to fix this?
zathrath03
Re: Can't expand volume after adding drive to RAID 5 storage pool
SOLVED:
Turns out you need to disable the SSD cache to be able to adjust the volume size. Not sure why, but it worked, so I guess the why doesn't really matter.
V8Triker
Post by V8Triker »
Thanks for posting the resolution, just in case it ever happens to me.
Saying that, I have 3 drives in RAID5, and then 2 in RAID1 for "safety".
Bikers know why dogs stick their head out the window.
TNAS F5-221
TOS 4.2.39-2203011626
3X WD RED PLUS 3TB (RAID5)
2X WD Green 2TB (RAID1)
1X WD 4TB USB
