F4-220 does not recognize new hard drives - repeated beeps
brock94
Post by brock94 »
I have a problem with my F4-220 NAS. I deleted the old storage pool (RAID 5 4x3TB) and bought new hard drives (4x WD60EFRZ).
Now I wanted to install it, but the NAS beeps every few seconds. I can't reach the NAS by IP and it doesn't react to anything. What now?
Thanks in advance
TMS
Re: F4-220 does not recognize new hard drives - repeated beeps
Post by TMS »
Please refer to the method two of this link to reinstall the system:viewtopic.php?f=75&t=423
brock94
Post by brock94 »
brock94 wrote: ↑01 Feb 2021, 19:40 Hi,
Thanks in advance
Here is the problem:
4. Wait about two minutes, after the network light is on, insert your hard drives;
the network light does not turn on...it only beeps again and again
{L_BUTTON_AT}brock94
May I know how did you process the replacement from 3TB drives to 6TB drives?
brock94
Post by brock94 »
TMroy wrote: ↑01 Feb 2021, 23:23 May I know how did you process the replacement from 3TB drives to 6TB drives?
Sure, I deleted the storage pool and shutdown the nas. After that i installed the new ones. I didnt found a correct best practice for this, so this was logical to me...
Did you use several new hard drives or several old hard drives when you reinstalled the system? Did you delete the storage pool after deleting the deleted volume?
Can you operate the fifth step when the network light does not turn on in the fourth step?
brock94
Post by brock94 »
I deleted the storage pool and the volumes, after that i inserted the new harddisks, after that step the problem began...
kainruben
Post by kainruben »
I have the same problem with the F2-210
I am trying to use the same HDD formated, but LAN Led doesn't work.
I had the lastest firmware installed.
Hello, The LED light of your device may be controlled by the system. Maybe the small system on your TNAS motherboard is broken. Is there any flashing at the network port behind the device? Can you still use the TNAS PC to install the system when the network indicator is off? If possible, please continue the installation to repair the boot system on the motherboard.After installation, the LAN led and HDD led will light up. If not, you need to operate according to the following:viewtopic.php?f=75&t=1455
{L_BUTTON_AT}kainruben
Hello, Is the LAN led light off when the system is installed or after the system is installed? Maybe the small system on your TNAS motherboard is broken. Can it be searched by TNAS PC if it is not illuminated during installation? If you can find it, you can continue to install the system.After the installation is complete, the led will light up. If not, you need to operate according to the following:viewtopic.php?f=75&t=1455
Return to “Initialization”
