[ Syncthing ] Continuous Replication/Cluster Sync
About: https://syncthing.net/
Applicable models: x.64 series, ARMv8 series
Applicable TOS5: 5.0.135 or later versions
To download the app: https://tmnascommunity.eu/download/syncthing
How to install a third party app in your TOS?
http(s)://yournasip:port/modules/SyncThing/www
Something you need to pay attention during your installation:
Firewall rules (for WAN) and remote access :
Port Forwards
If you have a NAT router, the easiest way to get a working port forward is to make sure UPnP is enabled – syncthing will handle the rest. If this is not possible or desirable you should set up a port forward for port 22000/TCP, or the port set in the Sync Protocol Listen Address setting.
Local Firewall
If your PC has a local firewall, you will need to open the following ports for incoming traffic:
Port 22000/TCP (or the actual listening port if you have changed the Sync Protocol Listen Address setting.)
Port 21025/UDP (for discovery broadcasts)
Remote Web GUI
To be able to access the web GUI from other computers, you need to change the GUI Listen Address setting from the default 127.0.0.1:8384 to 0.0.0.0:8384. You also need to open the port in your local firewall if you have one.
What is it?
gcok
Re: [ Syncthing ][ 1.12.1.0 ]Continuous Replication/Cluster Sync
Post by gcok »
thank you,
is there any plans to release an armv8 app of syncthing ?
Added armv8 version. You have to test yourself and let me know if it works.
I don't have an arm NAS yet to test it myself.
gcok
Post by gcok »
ok thanks I will get back to you shortly with an update
Tsim
Post by Tsim »
Firstly Thank you for these packages, amazing work.
With SyncThing, is there any issues upgrading the versions inside the NAS?
Normally should be no issues, folders used for app and settings are outside the TOS folders.
Tsim
Post by Tsim »
Thanks for the reply.
I am a noob on on the linux front.
Do you have any suggestions on the following?
I am assuming I need to SSH into the TNAS, but lost from there
2021-07-05 18:12:03: upgrading: open /mnt/md0/application/SyncThing/bin/syncthing/syncthing019605443: permission denied
edward56
Post by edward56 »
I install the Syncthing but i have this error when I try to open the app.
I try to open this url, but no working.
http://yournasip:8888/gui/
I am logged with the admin user.
yerc1
Post by yerc1 »
{L_BUTTON_AT}edward56
I also use Syncthing on my TNAS, although my way is different - as a Docker container.
The address I use to get to the WebUI is mynasip:8384.
F2-221
edward56
Post by edward56 »
{L_BUTTON_AT}yerc1
Hello, still doesn't work for me.
I have installed several @outkastm applications and I get the same error.
