Target Users:
Users currently running TOS 7.0.0746 or later versions.
Note:
If your TOS version is TOS 6, please refer to the TOS 7 update instructions first.
Important: This update is only applicable to TOS 7.0.0746 and newer. Users with older versions must first upgrade to 7.0.0746 before applying this update.
Here, we sincerely thank @apvm, @nitzer71, @rfbjr, @sianderson, @ambul, @Alak, @DJRush, @Claus, @crisisacting, @Gremlin, @OttO1916, @joka388, @bull5, @storageninja, @exqo, @1inkman, @snapsh0t, @dplegue, @mnewland, @enryx, @mcvh and others for your sharing and feedback. Your support helped us quickly identify and fix multiple issues.
Release Notes:
This update adopts a phased gray release strategy to ensure stability across different device models and network environments.
Phase 1 (Starting Today): The manual update package is now available for download on our forum. It will be rolled out in batches based on system version, device model, and region.
Phase 2 (Next Tuesday): The full online push will officially begin. At that time, all users will receive an update notification and can complete the update by following the on-screen prompts.
Update Notes
Bug Fixes:
1. Fixed the issue where access restrictions for special directories were incomplete in some File Manager APIs.
2. Fixed the issue where the same domain user had inconsistent UIDs when multiple servers joined the same AD domain.
3. Fixed the issue where redundant INFO files were automatically generated in the root directory after a system update.
4. Fixed the issue where some file names could be displayed as garbled characters when downloading files in Safari.
5. Fixed the occasional issue where the CAPTCHA image did not appear after multiple incorrect password entries when TNAS.online was enabled.
6. Fixed the issue where the status of domain users could be displayed incorrectly after refreshing the domain user list.
7. Fixed the issue where an extra Recycle Bin directory was created after selecting all files in the Recycle Bin directory and deleting them.
8. Fixed some other known issues.
Important Information:
Update Procedure:
1.Download TOS 7.0.1422 update package (MD5: 0a19f63beb0716b27833a64635c4015d);
2.Go to TOS > Control Panel > General Settings > System > Update;
3.Select "Manual Update" and upload the downloaded update package file;
4.Follow the prompts to complete the update;
5.After the system update is complete, please refresh your browser;
6.The TNAS IP address may change after the update. If you cannot connect to your TNAS using the previous IP address, use the TNAS PC client to search for the new IP address;
Client Downloads:
1. Download TNAS PC 5.2.560 for Windows OS.
- MD5: 1CFAF91C2ED5FD094C8C7EAD97A94D16
2. Download TNAS PC 5.2.560 for macOS (x86 architecture).
- MD5: 5F770271CBCCD8F0604176FD6E0C9FB1
3. Download TNAS PC 5.2.560 for macOS (ARM architecture).
- MD5: ECEB0837F1C754571E6E320300273AB0
4. Download TNAS PC 5.2.560 for Linux.
- MD5: 81204CE6A7ACD1668172B81CBB77E2FC
5. TNAS mobile for Android: Please search for "TNAS mobile" in the app store to install.
6. TNAS Mobile for iOS: Please search for "TNAS mobile" in the App Store to install.
TOS 7.0.1422 (x86) Official Release Update
Re: TOS 7.0.1422 (x86) Official Release Update
Passage sans souci à la nouvelle version. Toujours pas de liste déroulante avec les différents comptes sur la page d'accueil de Firefox
Pour le reste, tout fonctionne sans souci apparent
Bonne journée à toute l'équipe.
