TOS 7.0.1298 (x86) Official Release Update
Target Users:
Users currently running TOS 7.0.0746 or later versions.
Note:
If your TOS version is TOS 6, please refer to the TOS 7 update instructions first.
Important: This update is only applicable to TOS 7.0.0746 and newer. Users with older versions must first upgrade to 7.0.0746 before applying this update.
Here, we sincerely thank @rfbjr, @DmMc, @EgorA, @apvm, @crisisacting, @sianderson, @ambul, @Alak, @Gremlin, @nitzer71, @Solbot, @angelo1761, @killwithpower, @OttO1916, @exqo, @Pe6yc, @qidi4feet, @Silko, @MacStainless, @Crashoveride, @nolan39, @Argonautica, @vitali and others for your sharing and feedback. Your support helped us quickly identify and fix multiple issues.
Release Notes:
This update adopts a phased gray release strategy to ensure stability across different device models and network environments.
Phase 1 (Starting Today): The manual update package is now available for download on our forum. It will be rolled out in batches based on system version, device model, and region.
Phase 2 (Next Tuesday): The full online push will officially begin. At that time, all users will receive an update notification and can complete the update by following the on-screen prompts.
Update Notes
Bug Fixes:
1. Fixed the issue where some TOS apps (running in containers) could not be opened after being installed online from the App Center.
2. Fixed the issue where the account input field on the login page could not be focused automatically and required a manual click before text could be entered.
3. Fixed the issue where the Apply button was abnormally grayed out after clicking the refresh button to sync the time with the time server.
4. Fixed the issue where the time server drop-down list could still be operated while the time was being synced after clicking the refresh button.
5. Fixed the issue where the page kept showing a loading state without any error message when a non-image file was selected for the avatar upload.
6. Fixed the issue where the tooltip text was blank when hovering over the audio player icon in the navigation bar.
Important Information:
Update Procedure:
1.Download TOS 7.0.1298 update package (MD5: df4a6e4769b3c24491961601a7cd9ba6);
2.Go to TOS > Control Panel > General Settings > System > Update;
3.Select "Manual Update" and upload the downloaded update package file;
4.Follow the prompts to complete the update;
5.After the system update is complete, please refresh your browser;
6.The TNAS IP address may change after the update. If you cannot connect to your TNAS using the previous IP address, use the TNAS PC client to search for the new IP address;
Client Downloads:
1. Download TNAS PC 5.2.548 for Windows OS.
- MD5: 72701B52336AF9FD8B97A6BE9D5D5A7C
2. Download TNAS PC 5.2.548 for macOS (x86 architecture).
- MD5: BAA63A179C43F73965EA9C31EEB9D61E
3. Download TNAS PC 5.2.548 for macOS (ARM architecture).
- MD5: BB933DA867058884C4ADFE44EAD24AFC
4. Download TNAS PC 5.2.548 for Linux.
- MD5: 06FE93F9FFE47147854A34F28D57FCC2
5. TNAS mobile for Android: Please search for "TNAS mobile" in the app store to install.
6. TNAS Mobile for iOS: Please search for "TNAS mobile" in the App Store to install.
crisisacting
Re: TOS 7.0.1298 (x86) Official Release Update
Post by crisisacting »
Installed on stand-alone TNAS without any issues; will await second phase for testbed TNAS units.
rfbjr
Post by rfbjr »
All devices updated w/o issue
Comment about snapshot update process:
After updated, shouldn't the date be today (bottom right)?
F4-424 Pro (x2) at 7.0.1298
rfbjr wrote: ↑09 Oct 2026, 19:01 After updated, shouldn't the date be today (bottom right)?
In the new version of the TOS, it is used to display the date the app was installed rather than the date it was updated.
rfbjr
Post by rfbjr »
Nitrokalel
Mexico
Post by Nitrokalel »
F8 SSD Plus (8x4TB NVMe, TRaid, 48GB, prod) update ok
F8 SSD Plus (6x1TB+2x2TB, TRaid, 48GB, prod)update ok
F4-424 Pro (2x22TB+2x10TB HDD +1TB+500GB NVMe, TRaid, 32GB, prod) update ok
F2-423 (2x18TB, TRaid, 32GB, prod) update ok
F2-221 (6TB+10TB, TRaid, 10GB, prod) update ok
D1 SSD (2TB, prod) no problem is recognized
D1 SSD (2TB, prod)
Alak
France
Post by Alak »
Bonsoir,
La mise à jour s'est parfaitement passée et tout reste accessible :-)
Je me permet tout de même deux remarques (mode enquiquineur...)
- En premier, sur la page de connexion sous Firefox.
Que ce soit les Nas QNAP ou Synology, il m'est directement proposé dans un cadre, sous le champ de saisie, la liste de tous les comptes que j'ai enregistrés sous Firefox (comme dans tous les sites où l'on doit se connecter lorsque l'on utilise le gestionnaire de mots de passe et que nous avons entré différents comptes). Voilà une petite image pour me faire comprendre :
Avec la page de Terramaster (merci déjà d'avoir directement mis le "focus" sur le champ adéquat), mis à part le "rafraichissement" lors de l'installation de la nouvelle version où tout fonctionne à merveille, cela ne marche pas pour une connexion classique. Pourtant, cela fonctionnait parfaitement avec TOS 6, par le passé. Une petite image de ma page Terramaster :
C'est du pur détail, mais c'est moins pratique. Il faut alors faire un clic droit avec la souris sur le champ et rechercher dans le menu contextuel "utiliser le mot de passe enregistré" pour obtenir la liste. Ou alors, taper au clavier le nom d'utilisateur que l'on veut utiliser :-)
Voilà pour ma première remarque et cela vient peut-être de Firefox...
- En second, j'ai acheté un TERRAMASTER D6-320 tout récemment (super, entre parenthèse !)
Ce qui est moins formidable, c'est que sur une extension de votre marque, non seulement elle est transparente dans le système TOS 7 (il serait bon, à mon avis, de signaler que le matériel est raccordé à un des ports du NAS, en signe de reconnaissance), mais de plus, il faut passer par Windows, donc raccorder la boite à un système extérieur à votre entreprise, pour mettre à jour le Bios si l'on doit le faire un jour.
C'est super que ce soit possible depuis windows. Mais que vous n'ayez rien prévu depuis votre propre système ??? enfin ce que j'en dis :-) Dans tous les cas il fonctionne du tonnerre et j'ai pu ajouter des capacités de stockage sans aucun souci, que ce soit des volumes ou des pools de stockage. Mais je m'attendais à un petit "bonus" en le raccordant à une de vos propres machines, je l'avoue...
En attendant, tout est efficace et fonctionnel avec cette nouvelle version de TOS. Merci encore à toute votre équipe de développeurs !
PS : si vous désirez une photo de ce que propose Synology, je le ferais avec plaisir, mais c'est très semblable à ce que propose Qnap à la connexion sous Firefox : j'ai une liste qui me "mâche" le travail, comme je l'avais sous TOS 6
Lorsque je redémarre mon F'-424 depuis l'interface, après le temps d'attente, l'actualisation automatique de la page de connexion affiche également la liste. Mais si je me connecte et que je me déconnecte, ce n'est plus le cas, comme si la page "tuait" le pop-up de Firefox.
J'ai fait le test depuis différents PC et c'est strictement identique : sous Firefox, la liste des connexions enregistrées ne s'affiche plus. Notez encore que c'est du détail mais avec TOS6, tout fonctionnait comme attendu.
Promis, c'est ma dernière remarque sur le sujet : je vais juste m'y faire :-)
:ugeek: F4-424 :ugeek:
:ugeek: D6-320 :ugeek:
EriChan
Post by EriChan »
Alak wrote: ↑10 Oct 2026, 04:10
Thank you very much for updating to TOS 7.0.1298 and sharing such detailed and constructive feedback!
1. Regarding the Firefox login autofill issue:
Thank you for your feedback! We have confirmed that this issue indeed exists and has been submitted to our product team for evaluation and optimization.
2. Regarding D6-320 device identification and firmware management in TOS:
We are glad to hear that your D6-320 is performing well for storage expansion!
That said, your suggestions regarding natively identifying the official hardware model in TOS, as well as supporting firmware management directly within the TOS system, have both been forwarded to our product and hardware engineering teams for evaluation.
Thank you again for your valuable input and support for our team!
apvm
Post by apvm »
Updated, if there is any problem, will report here. Thanks.
F4-424
Two D4-320
Nikdfish
Post by Nikdfish »
Updated without issue from 7.0.0777. F2-423 & D4-320
F2-423 TOS 7.0.1298 20GB RAM, 2x NVMe drives (.25TB + 1TB JBOD as Volume1), 2x 12TB TRAID as Volume2 D4-320 4x 8TB TRAID as Volume3
