SyncThing Not Running after TOS 7 Upgrade
trmpeter
Post by trmpeter »
Hi SyncThing support
I have F2-424 recently upgraded to TOS 7.0.1278.
This upgrade caused SyncThing service unable to start. See the screenshot.
I then uninstalled (configuration not removed) and installed the program. The situation remained the same.
I navigated to /usr/local/@APP_CONFIG//SyncThing/SyncThing_start.log.
i saw error below:
27/09/26 17:05:53 Config folder exist at /usr/local/@APP_CONFIG/SyncThing
27/09/26 17:05:53 config symlink doesn't exist, will be created
MODCONFIGPATHHOME=/home/<username>/MOD_CONFIG/SyncThing
MODCONFIGPATH=/usr/local/@APP_CONFIG/SyncThing
MAIN_VOLUME=/Volume2
HOME_VOLUME=/Volume2
DATAPATHFULL=/Volume1/SyncThing
DATAVOL=/Volume1
27/09/26 17:05:53 Sync folder at /Volume1/SyncThing
SyncThing service is not running, will start it now
SUCCESS!
2026-09-27 17:05:53 ERR Failed to ensure directory exists (error="mkdir /usr/local/@APP_CONFIG/SyncThing: permission denied" log.pkg=main)
I ran the command to give SyncThing full access to the affected folder:
chown -R syncthing:users /usr/local/@APP_CONFIG/SyncThing
And it still didnt help.
Hopefully any experts can share your thought here to fix the issue. Thanks!
EriChan
Re: SyncThing Not Running after TOS 7 Upgrade
Post by EriChan »
trmpeter wrote: ↑28 Sep 2026, 06:12
SyncThing is a community-maintained application.
Please head over to the dedicated community support thread below to seek assistance from the community developers for further troubleshooting:
viewtopic.php?t=1515
Thank you for your understanding and support!
This app need to be updated for TOS7 to work properly. Will be done asap
Return to “Others”
