Export VM to a folder, then copy the folder to another NAS, in this case both are F4-424 Pro.
Import the OVA file, error "failed to retrieve data", log doesn't show anything, other than entries for creating the storage and network.
Where is the actual location of the log anyway?
I tried loading an ISO and that process worked.
Are there any restrictions on exporting/importing OVA files?
[Help] Export then Import
F4-424 Pro (x2) and F4-425 Plus at 7.0.1536
F6-424 Plus at 7.1ß
D4-320 & D4-SSD
F6-424 Plus at 7.1ß
D4-320 & D4-SSD
- paperiogame
Re: [Help] Export then Import
Check whether the OVA export is compatible with the destination TOS/VirtualBox version and verify the file is fully copied and intact, as an incomplete or unsupported OVF/OVA archive can cause the generic “failed to retrieve data” error.
I don't use VirtualBox on TOS, never have. One NAS running VMs export a VM and trying to import that VM into a different NAS using VMs.
Presently I don't have a second NAS running VMs any longer. One day I'll give it a try. It might have been the size of the OVA it created. Still if that was the case, why let the export create a file that large if it can't be imported.
F6-424 Plus at 7.1ß
D4-320 & D4-SSD
F6-424 Plus at 7.1ß
D4-320 & D4-SSD
