TOS 7.0.1278 (x86) Official Release Update
Target Users:
Users currently running TOS 7.0.0746 or later versions.
Note:
If your TOS version is TOS 6, please refer to the TOS 7 update instructions first.
Important: This update is only applicable to TOS 7.0.0746 and newer. Users with older versions must first upgrade to 7.0.0746 before applying this update.
Here, we sincerely thank @crisisacting, @Alak, @rfbjr, @apvm, @Nitrokalel, @OttO1916, @DmMc, @ambul, @sianderson, @mnewland, @kmatas, @Metrogeek, @nenominal and others for your sharing and feedback. Your support helped us quickly identify and fix multiple issues.
Update Notes
Bug Fixes:
1. Fixed the issue where the CPU temperature alarm policy was not properly adapted for certain models.
2. Fixed the issue where the message center process occasionally used excessive memory.
3. Fixed the issue where deleting the home directory gave no error prompt after enabling the safe box.
4. Fixed the issue where network connectivity checks were requested too frequently.
5. Fixed the issue where the entire folder was skipped without recursively comparing subfiles when uploading, copying, or moving a folder to a directory containing a folder with the same name.
6. Fixed the issue where subfolders in the “Select Folder” dialog of some features were not sorted by name.
7. Fixed the issue where SMB login for a newly created system user might fail after joining an LDAP domain.
8. Fixed the issue where an app was not immediately displayed in the “Installed” list after installation completed.
9. Fixed the issue where app user permissions were not saved after switching to the user page when creating a shared folder.
10. Fixed the issue where selecting all from the table header could not check the admin user group when editing app permissions.
11. Fixed the issue where an incorrect message was displayed when enabling SSH in a Traditional Chinese environment.
12. Fixed the issue where some option colors did not follow the theme color when creating a VPN.
13. Fixed the issue where a “url:null” prompt appeared when closing some dialogs.
14. Fixed various other known issues.
Important Information:
Update Procedure:
1.Check for updates online or download TOS 7.0.1278 update package (MD5: 22c64e3f9279427d29eb47801589da61);
2.Go to TOS > Control Panel > General Settings > System > Update;
3.Select "Manual Update" and upload the downloaded update package file;
4.Follow the prompts to complete the update;
5.After the system update is complete, please refresh your browser;
6.The TNAS IP address may change after the update. If you cannot connect to your TNAS using the previous IP address, use the TNAS PC client to search for the new IP address;
Client Downloads:
1. Download TNAS PC 5.2.548 for Windows OS.
- MD5: 72701B52336AF9FD8B97A6BE9D5D5A7C
2. Download TNAS PC 5.2.548 for macOS (x86 architecture).
- MD5: BAA63A179C43F73965EA9C31EEB9D61E
3. Download TNAS PC 5.2.548 for macOS (ARM architecture).
- MD5: BB933DA867058884C4ADFE44EAD24AFC
4. Download TNAS PC 5.2.548 for Linux.
- MD5: 06FE93F9FFE47147854A34F28D57FCC2
5. TNAS mobile for Android: Please search for "TNAS mobile" in the app store to install.
6. TNAS Mobile for iOS: Please search for "TNAS mobile" in the App Store to install.
rfbjr
Re: TOS 7.0.1278 (x86) Official Release Update
Post by rfbjr »
All four updated w/o issue
F4-424 Pro (x2) and F4-425 Plus at 7.0.1536
F6-424 Plus at 7.1ß
D4-320 & D4-SSD
DmMc
Post by DmMc »
The update finished successfully.
F4-425Pro
EgorA
Post by EgorA »
Container manager does not work after update
but dockhand works well
Upd. Few minutes later container manages appear to be disabled so I need to enable it manually.
Upd2. Process redis-server has a permanently high network activity - it constantly consumes 1Mb/s download traffic
F4-423
apvm
Post by apvm »
Downloaded the update file and log into f4-424 and system said there is a new update 1278, i still use the downloaded file to manual update instead of using the download and update option, everything seems to work fine, will inform if any problem. So I think this is an offical update instead of a beta update. Good Job if there is no problem.
BTW, docker manager work fine for me, I think maybe my system and app (volume 1) are two 256gb NVME M2 SSD Traid help with less problem, I am not sure though.
F4-424
Two D4-320
crisisacting
Post by crisisacting »
Stand-alone TNAS updated without issue.
sianderson
Post by sianderson »
both updated without issues
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
ambul
Post by ambul »
An old issue has returned—one that hadn't been seen since the very first versions of firmware 7.
It is impossible to access the web interface, yet TNAS PC can see the folders.
F8 SSD Plus MADN0301. V02 TOS 7.0.1536
Alak
France
Post by Alak »
Tout fonctionne :-)
:ugeek: F4-424 :ugeek:
:ugeek: D6-320 :ugeek:
Several errors on monitor for F2-424:
CIFS: VFS: cifs_mount failed w/return code = -113
CIFS: VFS: Error connecting to socket. Aborting operation.
Despite the "abort" it still seems to keep trying for several more attempts :(
Frustrated Beta Tester!!!
