Target Users:
Users currently running TOS 7.0.1113 (ARM) or later versions.
Applicable Models:
F2-211, F2-212, F4-212
Note:
If your TOS version is TOS 5.1 or TOS 6 Beta, please refer to the TOS 7 ARM official release announcement.
If you are on a different TOS 7 Beta version, please refer to the TOS 7 update guide first.
Here, we sincerely thank @Flatron, @byo12us2z, @hk87, @crisisacting, @funnyplace, @Lukin, @pennypacker, @Gremlin, @FredMutter, @Flyingbike, @Arktander, @tetrapack15, @Jragg and others for your sharing and feedback. Your support helped us quickly identify and fix multiple issues.
Release Notes:
This update adopts a phased gray release strategy to ensure stability across different device models and network environments.
Phase 1 (Starting Today): The manual update package is now available for download on our forum. It will be rolled out in batches based on system version, device model, and region.
Phase 2 (In One Week): The full online push will officially begin. At that time, all users will receive an update notification and can complete the update by following the on-screen prompts.
Update Notes
Bug Fixes:
1. Fixed the issue where local SMTP email notifications failed to send in some scenarios.
2. Fixed the issue where SMB advanced settings could not be properly configured in some scenarios.
3. Fixed the issue where the page might incorrectly prompt a failure when migrating shared folders.
4. Fixed the issue where the database usage of file task records for copy and move operations was not detected in a timely manner.
5. Fixed the issue where some applications could not scan USB device data.
6. Fixed the issue where NFS mounting failed when the remote directory contained spaces.
7. Fixed the issue where the SMB mount prohibition rule became invalid after enabling the Guest user.
8. Fixed the issue where downloading large files during remote access might stop after a period of time.
9. Fixed the issue where regular users failed to save files to their user directory via the text editor in File Manager.
10. Fixed various other known issues.
Important Information:
Update Procedure:
Manual Update:
1.Download TOS 7.0.1225 update package (MD5: 764dedd52be3789a3f2cd6f86817d706);
2.Go to TOS > Control Panel > General Settings > System;
3.Under "Manual Update", upload the update package;
4.Click "Apply";
5.After the system update is complete, please refresh your browser;
6.The TNAS IP address may change after the update. If you cannot connect to your TNAS using the previous IP address, use the TNAS PC client to search for the new IP address;
Client Downloads:
1. Download TNAS PC 5.2.548 for Windows OS.
- MD5: 72701B52336AF9FD8B97A6BE9D5D5A7C
2. Download TNAS PC 5.2.548 for macOS (x86 architecture).
- MD5: BAA63A179C43F73965EA9C31EEB9D61E
3. Download TNAS PC 5.2.548 for macOS (ARM architecture).
- MD5: BB933DA867058884C4ADFE44EAD24AFC
4. Download TNAS PC 5.2.548 for Linux.
- MD5: 06FE93F9FFE47147854A34F28D57FCC2
5. TNAS mobile for Android: Please search for "TNAS mobile" in the app store to install.
6. TNAS Mobile for iOS: Please search for "TNAS mobile" in the App Store to install.
TOS 7.0.1225 (ARM) Official Release Update
